Search Channel Entries based on URL_Title
January 05, 2012 4:50pm
  • #1 / Jan 05, 2012 4:50pm
    artlab
    I am trying to located particular channel entries that have a URL_Title with a specific string.
    Some of our URL_Title are of the form Title_2006
    So I want to locate all entries that have the _2006 in the URL_Title in a particular channel.  The 2006 is not in the Title or in the body, so a standard CP search does not work.
    Is there a way to do this or can I write some kind of SQL query in the Tools>SQL Manager?
  • #2 / Jan 06, 2012 4:34pm
    Dan Decker
    Hi artlab,
    While you could create a query that would return those entries, you wouldn’t be able to edit them in via the SQL Manager. You might be interested in an add-on called Zenbu that adds several more searching options for editing entries.
  • #3 / Jan 06, 2012 5:28pm
    artlab
    Zenbu doesn’t allow this it seems.  Not URL_Title search at least.
    If you can tell me the query, just having the resultant list by ID or name would help!  At least it narrows down the search.
  • #4 / Jan 06, 2012 5:35pm
    Dan Decker
    You can try running this in the Query Form:
    SELECT * FROM exp_channel_titles WHERE url_title LIKE '%_2006%'
    That should return a list of results where the url_title contains “_2006”. That result set will include the entry ID and the Title for the entries you are looking for as well.
    Hope that helps!
