Database problem
January 01, 2012 11:30pm
  • #1 / Jan 01, 2012 11:30pm
    Ali-ahmadi
    Hello!
    i can not access my database, when i wanna login the following error appears please help me to solve this problem.
    A Database Error Occurred
    Error Number: 1054
    Unknown column ‘hs.d_0’ in ‘field list’
    SELECT ct.title, hs.entry_id, hs.d_0 AS hits FROM (`exp_hits_stats` hs) LEFT JOIN `exp_channel_titles` ct ON `hs`.`entry_id` = `ct`.`entry_id` WHERE `hs`.`type` = 1 AND `hs`.`year` = ‘2012’ ORDER BY `hs`.`d_0` DESC LIMIT 10
    Filename: third_party/hits/acc.hits.php
    Line Number: 124
    regards
    Ali
  • #2 / Mar 07, 2012 4:25am
    Ali-ahmadi
    when i click to my article the following Error appears to me
    please helpe me where can i correct this error?
    Error
    The following tag has a syntax error:
    {exp:hits:count_hits}
    Please correct the syntax in your template.
