Issue with auto_login
December 14, 2011 1:21pm
  • #1 / Dec 14, 2011 1:21pm
    LucasHibbard
    Hi All,
    I’m have a bit of trouble trying to get the auto_login for members to function.  Here is the code that I’m using for the login form:
    {exp:member:login_form id="login_form" return="site"}
             <ul class="cf-elements">
              <li>
                                    <label for="username">Username</label>
               <input type="text" class="txt" name="username" value="" />
              </li>
              <li>
                                    <label for="password">Password</label>
               <input type="password" class="txt" name="password" value="" />
              </li>
              <li>
                                    {if auto_login}
                                    <input class="checkbox" type="checkbox" name="auto_login" value="1" checked="checked"> Auto-login on future visits
              </li>
              <li>
                                    <a href="#password-form" class="addl-func">Forgot Password?</a>
               <input type="submit" value="Sign In" class="button" />
              </li>
             </ul>
            {/exp:member:login_form}
    I also have made sure that the “User Session Type” setting under the “Security and Session” is set to “Cookie Only”.  What I am seeing is that no matter what the state is of the checkbox for the auto_login, the cookie will expire in 30 minutes.  As far as I can tell, I am doing everything correctly.  Is there something that I am missing?
    Thank you all for you assistance,
    Lucas
  • #2 / Dec 15, 2011 3:58pm
    Dan Decker
    Hi Lucas,
    You are doing everything correctly. There is a bug in ExpressionEngine related to cookies for login. I have heard that it has been fixed in the next release, but at this time there is no real way around it. I know that’s not a great answer, but you aren’t alone, our very own sites are affected by it too.
  • #3 / Feb 07, 2012 1:43pm
    cozmir
    Has this issue been fixed in version 2.4?
  • #4 / Feb 10, 2012 6:07pm
    Dan Decker
    Hi cozmir,
    According to the change log for ExpressionEngine 2.4, the “remember me” bug was fixed.
    What version of ExpressionEngine are you currently using?
    Cheers!
