Dynamic channel name in exp:stats
December 14, 2011 10:20am
  • #1 / Dec 14, 2011 10:20am
    cliffdangler
    Is it possible to dynamically pass the channel name to the below (indicated in red)?
    {exp:stats channel="{DYNAMIC}”}{last_entry_date format="{DATE_W3C}”}{/exp:stats}
    I’ve even tried an embedded template, but to no avail:
    {exp:stats channel="{embed='includes/.test'}”}{last_entry_date format="{DATE_W3C}”}{/exp:stats}
  • #2 / Dec 15, 2011 2:32pm
    Dan Decker
    Hi cliffdangler,
    You could use Segment variables to set the channel in this fashion:
    {exp:stats channel=”{segment_2}”}{last_entry_date format=”{DATE_W3C}”}{/exp:stats}
    If you had a URL similar to this:
    <a href="http://your.domain.com/template-group/news">http://your.domain.com/template-group/news</a>
    The word “news” would be assigned to the {segment_2} variable and then the stats tag would use that to pull the stats for the “news” channel.
    In your second example, you simply can’t use embeds as part of a parameter. They are intended to embed other *templates*, does that make sense?
