Setting Variable for use in exp:channel:entries tags
December 13, 2011 4:44pm
  • #1 / Dec 13, 2011 4:44pm
    BPeddle
    I am trying to set a variable for the entry id for use in:
    {exp:channel:entries channel="channelname" entry_id="{embed:foo}” dynamic=“no” require_entry=“yes” limit=“1” disable=“pagination|member_data|categories|category_fields”}<title>{title}</title>{/exp:channel:entries}
    I can use {segment_3} for example without issue.
    I try to set
    {preload_replace:foo="12345"} and it doesnt worked with {embed:foo} or just {foo}
    I wrote a plugin that returns the value—{exp:entryid}
    That will output the number but it doesn’t seem to stick on the entry_id variable.
    I suspect its something simple I am doing wrong but at this point I am just going in circles.
    In the plugin I return the value—$this->return_data = “12345”;
    Any tips or insight is much appreciated.
  • #2 / Dec 14, 2011 11:48am
    tidy
    {preload_replace:foo="12345"} should work once this is just text (not plugin output etc) and above your channel entries tag and in the same template:
    {exp:channel:entries channel="channelname" entry_id="{foo}"...}
    If you put your channel entries tag in an embed, then you can pass a variable to it in the embed call and reference this within the embed:
    {!--main template calls embed--}
    {embed src="myembed" foo="12345}
    {!--myembed embedded template code--}
    {exp:channel:entries channel="channelname" entry_id="{embed:foo}"...}
    If you want to use the output of a plugin as a parameter in a channel tag, I think this should work. The parse inward bit is needed to have things parsed in the right order:
    {exp:channel:entries channel="channelname" entry_id="{exp:entryid}" parse="inward" ...}
    If this general info does not help, if you can outline exactly what you are trying to do, someone should be able to help.
  • #3 / Dec 14, 2011 12:15pm
    BPeddle
    Tried a few ways you recommend
    {exp:channel:entries channel="channelname" entry_id="{exp:entryid}” parse=“inward” dynamic=“no” require_entry=“yes” limit=“1” disable=“pagination|member_data|categories|category_fields”}<title>{title}</title>{/exp:channel:entries}
    When I view debug code it becomes
    {exp:channel:entries channel="channelname" entry_id="M00o93H7pQ09L8X1t49cHY01Z5j4TT91fGfr" parse="inward" dynamic="no" require_entry="yes" limit="1" disable="pagination|member_data|categories|category_fields"}
  • #4 / Dec 14, 2011 12:31pm
    tidy
    I think you might be coming up against this weirdness:
    http://blog.ericlamb.net/2011/05/expressionengine-and-the-mystery-of-m00o93h7pq09l8x1t49chy01z5j4tt91fgfr/
    Do you also output {exp:entryid} elsewhere in the same template?
    It could be using it multiple times at different levels that is causing this - not sure, have not come up against this before myself.
    If that;s the case, to debug, could you try removing all other references to {exp:entryid} apart from the one in the channel entries tag parameters and see if that works?
  • #5 / Dec 14, 2011 12:36pm
    BPeddle
    I removed the {exp:entryid} as output as I was debugging and it worked.  I actually use it twice in the exp:channel tag without issue now.  It just didn’t like the output.
  • #6 / Dec 14, 2011 12:38pm
    tidy
    great glad you got sorted 😊
