EE variables and PHP input/output
December 02, 2011 11:41pm
  • #1 / Dec 02, 2011 11:41pm
    struiling
    I’m trying to implement single sign-on. Don’t need to go into implementation details on that, but they want a BASE64 encoded JSON string of relevant user data. Like so:
    <?php
    $data = array(
           "id" => "{logged_in_member_id}",
            "username" => "{logged_in_username}",
            "email" => "{logged_in_email}"
    $message = base64_encode(json_encode($data));
    Except. Even though EE is setting the info in the $data array correctly (i.e. [id] => “1”), when it’s base64’d, it’s encoding [id] => “{logged_in_member_id}” as a string literal.
    Here’s a stripped down example code that I’ve found will work in any PHP-enabled template. I’ve tried on input and output (seems output should be the right one), but it doesn’t seem to make a difference.
    <?php
    $data = array(
    print(json_encode($data) . "
    print($message);
    If the base64 string matches this:
    eyJpZCI6Intsb2dnZWRfaW5fbWVtYmVyX2lkfSIsInVzZXJuYW1lIjoie2xvZ2dlZF9pbl91c2VybmFtZX0iLCJlbWFpbCI6Intsb2dnZWRfaW5fZW1haWx9In0=
    it decodes to this (not what I want) :
    <!-- spaced out to prevent EE from interpreting -->
    {"id":"{
    logged_in_member_id
    }","username":"{
    logged_in_username
    }","email":"{
    logged_in_email
    This should be able to work, right? I’m on version 2.1.3. As a note, if you use the PHP base64_decode function and it decodes to {logged_in_username}, EE will interpret that and print the username. So I’ve been using a decoder website instead of the function.
    Any help is much much appreciated. Thanks!
  • #2 / Dec 03, 2011 2:14am
    @nnette
    My issue and yours are related.  How are you getting an EE tag to ever work within php?  I have my template setting to “Output” and it parses everything literal.
  • #3 / Dec 03, 2011 3:29am
    struiling
    Ah, I’m pretty sure it’s a parse order thing, where it turns out that there is a fair amount of EE tags that are still not processed until after PHP Output: http://expressionengine.com/wiki/Parse_Order/ . Including standard variables, which is what I really want in this case. Not sure how to get around this.
  • #4 / Dec 03, 2011 3:37am
    struiling
    I think one just has to get the info that’s from the standard variables directly with PHP. http://ellislab.com/forums/viewthread/82379/ . Funny how we both had the same problem right now!
  • #5 / Dec 03, 2011 6:07am
    @nnette
    Ok, I figured out my issue.  These two resources should help you:
    http://ellislab.com/expressionengine/user-guide/development/usage/session.html
    http://ellislab.com/expressionengine/user-guide/development/usage/database.html
    Try This:
    <?php
    $data = array(
            "id" => '".$this->EE->session->userdata('member_id')."',
            "username" => '".$this->EE->session->userdata('username')."',
            "email" => '".$this->EE->session->userdata('email')."'
    This is how I was using it:
    UPDATE `my_table`
    SET `my_field` = `my_field`+".$_POST["data"]." AND `my_field_2` = `my_field_2`-".$_POST["data2"]."
    WHERE `my_field_4` = '".$this->EE->session->userdata('member_id')."'
    LIMIT 1;
    Hopefully this information helps you as well.  😊
  • #6 / Dec 03, 2011 4:22pm
    struiling
    Hallelujah! I did
    $data = array(
           "id" => $this->EE->session->userdata('member_id'),
            "username" => $this->EE->session->userdata('username'),
            "email" => $this->EE->session->userdata('email')
    and all is well.
  • #7 / Dec 04, 2011 1:00pm
    Sean C. Smith
    Hi struiling,
    Glad you got that worked out. Is there anything else that you need help with?
    @nnette, Thanks for the assist.
    Sean
  • #8 / Dec 05, 2011 3:32pm
    struiling
    All set, thanks.
  • #9 / Dec 05, 2011 6:42pm
    Sean C. Smith
    Great, going to close this thread. Feel free to post again when needed.
    Sean
