Including one category and excluding another
December 01, 2011 2:38pm
  • #1 / Dec 01, 2011 2:38pm
    tcast
    I’ve got some entries that are categorized like so:
    Entry ID: #1865
    Categories: #10, #17.
    Entry ID: #1865
    Categories: #10
    I need to write an entries tag to get the first entry that has category id #10, and exclude id #17.
    Intutively, the tag should be something like this:
    {exp:channel:entries limit="1" category="10 not 17"}
    or
    {exp:channel:entries limit="1" category="10&!17"}
    I can’t use a conditional in the loop, because it has to be limited to one entry, and I can’t predict how far I’d have to loop through to find a matching entry, and I can’t break out of a loop when I find it anyways. It’s either a tag param I’m using wrong or missing, or I’ll have to pull it all out and write it as a php function in a module, which I reallllly don’t want to have to do in this instance, because this should be such a simple operation.
  • #2 / Dec 02, 2011 3:19pm
    Kevin Smith
    Hi tcast,
    I see what you’re trying to accomplish, but you’re suspicions are right: there’s not a native way to do that. The only thing I can think of to accomplish this natively is to negate all the categories you don’t want to appear and use the uncategorized_entries parameter to exclude entries that aren’t yet categorized. It’s not elegant, but it should work.
    Hope this helps!
