cp unstyled after update, normal solutions have not worked
November 30, 2011 11:40pm
  • #1 / Nov 30, 2011 11:40pm
    botkiller
    I just updated from 2.2.1 to 2.3.1 and while the frontend sites work fine, the control panel is unstyled. I have reviewed all the posts I could find and followed those suggestions but no joy. I have uploaded my cp_themes folder again, moved the folder to the system directory, dropped the db and reinstalled-reupdated twice from backup and every time there is no styling. I have removed my .htaccess and gone with none and used index.php and still no luck. I checked php settings on the server and open_basedir is not set. Host is Dreamhost. This used to work, what else can I try?
    From firebug while using .htaccess and removing index.php I am showing a 404 for all the cp_themes resources.  However, when I eliminate the .htaccess from the mix and run a standard index.php, the error becomes a 403 forbidden. I then chmod -R 777 the themes folder for kicks but with no effect.
    At the end of my tether here.
  • #2 / Dec 02, 2011 12:56pm
    Kevin Smith
    Hi botkiller,
    I’m sorry you’re running into this. It’s clearly been a frustrating experience for you. I tell you what: be on the lookout for an email from me, and I’ll see what I can do to get this wrapped up for you in short order.
  • #3 / Dec 02, 2011 1:00pm
    botkiller
    Thank you very much Kevin. I don’t understand why it didn’t work the first time, but I kept at it and late last night after uploading again and then chmod ing the permissions of the themes folder all is working.
  • #4 / Dec 05, 2011 8:36pm
    Kevin Smith
    Great! I’m so very glad to hear you got everything working, botkiller. Let us know if there’s anything else we can do to help.
