I am attempting to upload to Expression engine v 2.3.1 & MSM 2.1.1 using MetaWeblog API in MarsEdit 3.3.5 but sadly am getting a failure message
the marsedit error reads
“The post could not be published because of an error while uploading an attached file. If this problem persists, try deleting the attachment from the Uploads list and re-attaching it. Unable to Upload File.”
here is the header of the XML response:
URL: http://site.com/home/index.php?ACT=20&id=6
Method name: metaWeblog.newMediaObject
Network reply received: 2011-11-25 11:46:03 +0100
Status code: 200
Succeeded: NO
—Fault Error—
Fault code: 810
Fault string: Unable to Upload File
*note that site is housed in subfolder “home”*
Is there anything I should verify on the EE side of the configuration?
other steps so far
1- verified all paths
2- checked permissions chmod ‘ing to recommended 666 or 777 as appropriate
fwiw I recently upgraded the server and continue to get “openbasedir” warnings in the CP
(this may be unrelated and I am following up on config issue separately )
Has anyone else gotten this to work?
thanks!
