Combining search: and site params on MSM site
November 29, 2011 5:15am
Subscribe [5]
  • #1 / Nov 29, 2011 5:15am
    Andy Harris
    Hi, I’m pulling my hair out at this one. I have an MSM site with 5 sites, and I want to store all addresses on the main site but allocate them as required. To do this, I’ve created a P&T switch field for each site (display on site A, display on site B etc).
    On the main site, this works fine:
    {exp:channel:entries channel="office" disable="category_fields|member_data|pagination|trackbacks" dynamic="no" site="not gribbler" search:office_contracting="y"}
    {title}
    It returns all offices assigned to the contracting site.
    If I then go to the contracting site, and call this same code via
    {embed="main_site:shared/list_offices"}
    I get nothing back at all. However, if I remove the search parameter, I get back all sites as expected.
    It’s as if the search parameter stops working when I add site - it might be worth noting that I currently also have an office channel in my contracting site. Could it be that the search parameter isn’t respecting the site parameter and searching the wrong field?
  • #2 / Nov 29, 2011 5:22am
    Andy Harris
    I went into my contracting site and changed its office_contracting field to xoffice_contracting - this made the code then output ALL sites, so there seems to be a problem with using site and search: together….
  • #3 / Nov 29, 2011 6:14am
    ipixel (Australia)
    Does this work?
    {exp:channel:entries channel="office" disable="category_fields|member_data|pagination|trackbacks" dynamic="no" site="default_site" search:office_{site_short_name}=“y”}
    Where:
    channel=“office” is the channel you’re storing the addresses in
    site=“default_site” is the short name for the ‘main’ site the addresses are located
    And the specific field name for the P&T switch matches the short name for each of your websites too for the search parameter.
  • #4 / Nov 29, 2011 6:14am
    ipixel (Australia)
    Maybe also double check the status=“open” on all the office entries that you have.
  • #5 / Nov 29, 2011 6:19am
    Andy Harris
    No, sadly not. I changed my field on the main site from office_contracting to office_[short site name] and I now get all sites back, which is the same as what happened in my second post above.
  • #6 / Nov 29, 2011 12:10pm
    Oskar Smith
    Unfortunately, search: doesn’t work with MSM sites.
    See:
    this thread
    (amongst many threads - you’re not alone, I’ve needed this several times before myself too)
  • #7 / Nov 29, 2011 12:21pm
    Andy Harris
    Ah damn it. Cheers for that - I think I’ll put in two feature requests, the first of which is to put it in the sodding documentation so I don’t waste x hours trying to get it to work!!
  • #8 / Nov 29, 2011 7:52pm
    Sean C. Smith
    Andy,
    That is definitely a good feature request, sorry for the frustration.
