I tried to update from 2.2 to 2.3.1…
I followed all the steps to the T. I have done this a number of times before… but this time I received an error… and.. not being database savvy… I desperately need someone to help out here?
The initial reason for the update was that 2 of the channels (both use the same fields), started to “mess up”. If you went to PUBLISH or EDIT them, you would get the EDIT ENTRY… then PUBLISH | DATE | OPTIONS… followed by:
closed_eye.png” alt=“Delete” width=“15” height=“15” >
Then stuff would look ugly until TITLE on down.
Now this ONLY works with the entries for these 2 channels. And we are up to 348 entries.
And the other channels are perfect. No glitches.
What could have caused that? And is there any way to fix it??
thanks kindly!
otto
