hi support team,
after installing 2.3.1 version of EE i get blank white screen, what is wrong? no errors happened during installation process.
dmitry
November 17, 2011 5:24am
Subscribe [3]#1 / Nov 17, 2011 5:24am
hi support team,
dmitry
#2 / Nov 17, 2011 2:58pm
Hi Dmitry Romanovsky,
Can you tell us where you are seeing the white screen? On the front side, or in the Control Panel? Is this on a fresh install or an update from a previous, working installation? If you are unable to login to the Control Panel, can you open /system/expressionengine/config/config.php and set:
$config['debug'] = '1';This will display all PHP errors, if any, that are being generated.
#3 / Nov 20, 2011 2:15am
Hi Dan! I have debug = ‘1’ by default. I have blank screen in CP. May be any other ideas? I tried reinstall, the same effect, and no errors during install process. It’s a fresh install, nothing tricky
Dmitry
#4 / Nov 20, 2011 3:14am
Ohh, installing Hash module solved it!
#5 / Nov 20, 2011 3:31am
But now i can not login to CP, login/pass are correct but won’t let me in! Any ideas?
#6 / Nov 21, 2011 8:30pm
I’m unfamiliar with the Hash module - could you send me a link? Have you tried logging in to your CP with a different browser and/or clearing your cache?
Sean
