dompdf wrong content-type generated
November 10, 2011 12:07am
  • #1 / Nov 10, 2011 12:07am
    Interfacer
    Hi
    I am using dompdf as pdf generator. Everything works great on the live server except that its downloading the pdf with the wrong content type (text/html) as supposed to application/pdf. That causes issues with Safari appending the wrong extension (pdf.html).
    However setup works great locally with the proper content-type being used.
    I set the template to allow php, parse on output. Here is the template code:
    <?php
    require_once("assets/dompdf/dompdf_config.inc.php");
    $html = '
    <html>
    <head>
     <style>
     </style>
    </head>
     {exp:channel:entries status="completed|pending" channel="certificate" entry_id="{last_segment}"}
        <body>
            some html
     </body>
    </html>';
    $dompdf = new DOMPDF();
    $dompdf->load_html($html);
    $dompdf->render();
    $dompdf->stream("sampledoc.pdf");
    exit();
    If I save the template as file it sets the content type right but breaks in google chrome.
    I am using ExpressionEngine v2.2.2 - Build: date 20110801
    on apache 2 server with dompdf 0.6
    Cheers
  • #2 / Nov 10, 2011 12:40am
    Interfacer
    Issue is resolved. I saved the php template as file and than reverted back to saving file to db. Now the template is the proper content type.
  • #3 / Nov 10, 2011 5:11am
    Glad you are up and running again. Feel free to start a new thread if you have any more questions.
