White screen 1.7.1
November 07, 2011 8:19am
  • #1 / Nov 07, 2011 8:19am
    Henrik Eklund
    We had a problem with nGen File Field, EE 1.6.8, probably because the host upgraded to php 5.3.8. So i thought an upgrade to 1.7.1 would do the trick!
    But it went bad. The CP works fine, but the frontend is all white…
    It appears that the template cant show any weblog content anymore. If I make a new template with static text, it shows up fine. But if I put some weblog tag:
    {exp:weblog:entries weblog="" dynamic="off"}
     {title}
    {/exp:weblog:entries}
    it turns blank. I’ve tried to disable extensions, but same result. If i put same weblog categories tags:
    {exp:weblog:categories weblog='leder' disable='category_fields' show_empty='no'}
     <a path='leder'>{category_name}</a>
    {/exp:weblog:categories}
    it shows up fine. So it seems that something is wrong with the weblog tags… i really dont know.
    Thanks, Henrik
  • #2 / Nov 07, 2011 12:18pm
    Henrik Eklund
    No one?
  • #3 / Nov 07, 2011 1:52pm
    Henrik Eklund
    ok, referring to this post http://ellislab.com/forums/viewreply/880698/, i tried those solutions recommended in the thread, but no luck. Instead i replaced mod.weblog.php with the file from version 1.7.0 in order to get things to work. I know this is a very bad solution… but now it works.
    Thanks / Henrik
  • #4 / Nov 07, 2011 7:51pm
    Sean C. Smith
    Henrik,
    I need to ensure that your install isn’t running a mix of versions. The file mod.weblog.php had some major changes between 1.7.0 and 1.7.1. Could you re-upload all the file from 1.7.1? Also make sure that you don’t leave any of the 1.6.8 files behind. I’m not asking you to upgrade again, but rather to re-upload all the 1.7.1 files again to ensure that all files are the correct version.
    Also before doing anything make another backup of your files and database just as you did before the upgrade to 1.7.1
    There’s a good chance that ngen file is not compatible with the version of php that your host upgraded to as ngen hasn’t been updated since August 2010.
