Having some annoying problems with Date Fields & DST Settings.
After the clocks going back an hour on Sunday, we have turned DST ‘off’ to match the change. The problem is, the date/time updates and shows the correct time but every single date field on the system goes back 1 hour.
We have a massive list of events with ‘Start Times’ being one of the most important aspects. These are obviously being moved back 1 hour.
Any newly published entries have to be set 1 hour forward to accommodate the correct start time.
Am I wrong in thinking all Date fields should remain unaltered when switching DST settings? I’ve tried setting a Super Admin account as the master localisation and through the system-wide Localization settings, to no avail.
I’m either missing some glaringly obvious, or there’s an issue somewhere.
We are running 2.2.1, but didn’t notice anything in the changelog relating to this problem.
Hoping someone can shed some light on this, as I am lost with it as it stands.
-Wilko
