Safecracker stripping element style attributes
November 01, 2011 7:10pm
Subscribe [5]
  • #1 / Nov 01, 2011 7:10pm
    NAlbuquerque
    I’m having a strange issue with safecracker where it strips attributes from html elements in a textarea fieldtype. (This was also happening with a WYGWAM fieldtype, so I turned it into a textarea to troubleshoot.)
    For example, the style attribute on an image gets completely stripped when posted via safecracker. However, if I post via CP it’s fine.
    The fieldtype is set to textarea with XHTML formatting. If I manually add the style=“border:1px solid red” to the CP it posts and displays in the template fine.
    If I try the same thing via a safecracker form, the style attribute gets completely removed when I post.
    Any ideas of why this might be happening?
    I should add that I am running the latest version of EE (2.3.1).
  • #2 / Nov 02, 2011 3:59pm
    Hi, NAlbuquerque.
    I’d like to see if I can re-create the issue on a brand new version of EE 2.3.1. Can you post what you have in your SC form?
  • #3 / Nov 02, 2011 4:22pm
    Maheradmin
    Hi Sue, here is simplified form which I used to troubleshoot on a blank template. My channel only consists of a single WYGWAM fieldtype—although I’ve changed it to a textarea and it does the same thing.
    {exp:safecracker channel="group_posts" entry_id="{segment_4}" return="groups/view/{segment_3}" dynamic="no" include_jquery="yes"}
      <label for="title">Title</label>
      <input name="title" type="text" value="{title}">
     {field:group_posts_body}
       <input type="submit" value="Submit" class="no-padding">
    {/exp:safecracker}
  • #4 / Nov 04, 2011 2:59pm
    Kevin Smith
    Hi Maheradmin (and NAlbuquerque?),
    I was able to replicate the problem you posted about. Definitely looks like a bug, so I posted a bug report on your behalf here. I’d recommend adding a comment to that bug report so that you’re updated when a solution is posted.
    Thanks for letting us know about this bug!
  • #5 / Nov 04, 2011 3:14pm
    NAlbuquerque
    Thanks for the follow up!
  • #6 / Nov 07, 2011 4:09pm
    Dan Decker
    Ji NAlbuquerque,
    Since Kevin has posted the bug report, is there anything else we can assist you with?
  • #7 / Nov 07, 2011 4:13pm
    NAlbuquerque
    Nope, just need to get this sorted out for a site launch coming up.  I’ve signed up for notifications on the bug report so hopefully this will get fixed soon.
  • #8 / Nov 09, 2011 10:09pm
    Dan Decker
    Hi NAlbuquerque,
    Keep an eye out for progress on that bug report. If you need any other help in the meantime, please let is know in a new thread.
    Cheers!
