Check if a categorie is checked
November 01, 2011 6:46pm
  • #1 / Nov 01, 2011 6:46pm
    Guido Neele
    I would like to create a list with checked and unchecked categories. Something like ...
    {exp:channel:categories channel="channel_name" style="nested" id="list-id"}
      if category === checked
        <a class="checked">{category_name}</a>
      else
        <a class="unchecked">{category_name}</a>
    {/exp:channel:categories}
    or
    {categories}
      else
    {/categories}
    Is this possible?
  • #2 / Nov 02, 2011 5:52am
    Guido Neele
    Ok solved it by writing a plugin
    <?php
    if (!defined('BASEPATH')) exit('No direct script access allowed');
    class Is_checked {
        var $return_data = "";
        function __construct() {
            $this->EE =& get_instance();
            $entry_id = $this->EE->TMPL->fetch_param("entry_id");
            $cat_id = $this->EE->TMPL->fetch_param("category_id");
            $this->EE->db->where("entry_id", $entry_id);
            $this->EE->db->where("cat_id", $cat_id);
            $results = $this->EE->db->get("exp_category_posts");
            if ($results->num_rows() == 0) {
                $this->return_data = 0;
            else {
                $this->return_data = 1;
    /* End of file pi.is_checked.php */
    /* Location: ./system/expressionengine/third_party/is_checked/pi.is_checked.php */
    Code in template now looks like this:
    {exp:channel:categories channel="analyzers" style="nested" id="list-application-fields"}
       {if {exp:is_checked category_id="{category_id}" entry_id="{entry_id}"} == 1}
          <a href="http://{path=SITE_INDEX}class=supported">{category_name}</a>
       {if:else}
          <a href="http://{path=SITE_INDEX}class=unsupported">{category_name}</a>
  • #3 / Nov 02, 2011 10:14am
    Glad you found an add-on to accomplish this. Feel free to start a new thread if you have any more questions.
