Cookie settings are as follows:
.site1.com
.site2.com
.store.site1.com (is this correct? or should it be .site1.com/store)
After spending a lot of time reading relative threads I stumbled across people with very similar/the same issues and problems with the config file were mentioned a lot…
On inspection I noticed that the CP url was still set to the an older setup of EE - this strangely hadn’t updated?
Having changed it, it currently seems that in terms of login into EE and my multisite setup is working as it is suppose to be.
However, now I’m having several problems with my brilliant retail setup (store.site1.com), and suspect that they might be related?:
When I try to register a new user in BR, on submission of the form the page is returned with blank fields.
If I try to login as a current user, it says that I’ve logged in but I’m unable to consequently access the ‘user area’.
On the occasion that I have been in the ‘user area’ and tried editing the user’s profile on return the fields are returned blank.
At no point do I get any error messages.
Could these issues be relative to cookie setting with EE?
Regards.
