Parse Error from +Add button on CP
October 25, 2011 7:37am
  • #1 / Oct 25, 2011 7:37am
    daithi
    Hi
    I’m getting the following error when I try to add a quick link to any page on the CP:
    Parse error: syntax error, unexpected ‘,’, expecting T_FUNCTION in /MY_BASE_PATH/system/expressionengine/libraries/Messages.php on line 5293
    I’ve replaced my real base path with MY_BASE_PATH
    thanks
    d
    v2.3.0 - Build: date 20111011
  • #2 / Oct 25, 2011 11:11pm
    Dan Decker
    Hi daithi,
    I’m sorry to see this is happening, however I was unable to replicate this issue. Was this a fresh install or an update? I looked in Messages.php and it doesn’t even go to line 5293, only 5249. Can you try to replace the file on your install with the same file from a fresh download?
  • #3 / Oct 26, 2011 5:24am
    daithi
    Thanks for the response Dan.
    It was an update from 2.2.2 to 2.3.0. My Messages.php goes to 5426, including an easter egg! (attached)
    I’m uploading the new messages.php now! I’ll let you know how that goes.
    David
  • #4 / Oct 26, 2011 5:29am
    daithi
    Adding the messages.php from 2.3.1 appears to have fixed the issue.
    Thanks for your help
    David
  • #5 / Oct 26, 2011 11:20am
    Mark Bowen
    Hi David,
    Glad you’re all sorted now. Thanks for letting us know.
    If anything else crops up then please don’t hesitate to post again as needed.
    Mark
