Beginners Help with complex layout
October 24, 2011 3:15pm
Subscribe [4]
  • #1 / Oct 24, 2011 3:15pm
    laneo10
    I have downloaded and installed expression engine today and am just getting to grips with some of the fundamentals on how to use the system.
    I am currently trying to plug the cms into my portfolio which has quite a unique layout which throws up some inherent challenges on how to pull out entries.
    The basic layout for the projects can be seen here:
    http://testing.studiounkle.com/
    Now the difficulty that I have is the projects have a different layout per alternate row, and also within those rows each thumbnail has a different style or size.
    Some have the slide up caption style, others have the caption displayed under the thumbnail.
    I can’t quite get my head round how to do this because of the alternating rows and thumbnail styles.
    I have a suspicion that it could be done using a combination of status’s and conditionals.
    Can anyone explain to me the most economic way of achieveing this.
    Please bear in mind that I am a beginner with expression engine and have limited programming knowledge beyond plain html and css.
    Thanks in advance
    Dan
    Moved to Community Help forum by Moderator
  • #2 / Oct 25, 2011 4:40am
    laneo10
    Can anyone help with this at all please, Im really stuck.
    Cheers
    Dan
  • #3 / Oct 25, 2011 9:41am
    Hi, Dan. This appears to be the same question you posted earlier..
    http://ellislab.com/forums/viewthread/202720/
    Moving this to the Community Help forum for additional community support.
  • #4 / Oct 25, 2011 10:02am
    laneo10
    Thanks Sue,
    Id really appreciate it if someone could help out.
    I am attaching an image to show the basic pattern of the projects.
    I assumed that i would be able to use the switch to apply a different class in the sequence they come out of the system.
    So:
    Project 1 {float: left}
    Project 2 {clear: left}
    Project 3 {float: left}
    Project 4 {float: left}
    Of course this doesn’t work now becuase project 3 is dropping down.
    This is driving me nuts!!! haha
  • #5 / Oct 25, 2011 10:06am
    laneo10
    {exp:channel:entries channel="folio_projects"}
        <div class="{switch='project-1|project-2|project-3|project-4'}">
        images/img_2a.jpg
        <div class="cover boxcaption">
        <h3>{title}</h3>
    <p>    {project_caption}<br />
        </div>  <br />
         </div><br />
      </p>
    <p>    </p>
    <p>  <br />
    This is the code im using to pull the projects out of the system.
    Since this goes in a loop im also not sure how to tackle the alternate row
  • #6 / Oct 25, 2011 11:43am
    Kevin Cupp
    Hi Dan,
    If you need something to appear, say every 4 iterations of the loop, you can still use a {switch} statement like this:
    {switch='odd||||even||||'}
    See if that achieves your layout problem, and let me know if I’m not understanding the particular problem.
    Kevin
  • #7 / Oct 25, 2011 1:39pm
    laneo10
    Cheers Kevin, think I’m getting the hang of the switch now.
    I have just tried to create a conditional but i don’t think im doing it right.
    Below is the code
    <div class="{switch='one|two|three|four'} {thumbnail_type} {project_row}">
        images/img_2a.jpg
        {if "{caption_type}" == "sliding-small captionfull" OR "{caption_type}" == "sliding-large captionfull"}
            {!-- show single entry --}
        <h3>{title}</h3>
        {project_link}<br />
        </div><br />
        <br />
          {if:else}<br />
          </p><h3>{title}</h3>
            {/if} <br />
         </div><br />
      <br />
  • #8 / Oct 25, 2011 1:45pm
    Kevin Cupp
    It’s looking good to me. What is happening instead of what you expect to happen? If you output {caption_type}, does it indeed equal one of the types you’re checking for?
    It may also help to paste the HTML that the template is outputting, and put the {caption_type} variable in an HTML comment, that may help illustrate what is actually happening versus what the template looks like it should do.
  • #9 / Jan 29, 2012 12:58am
    kimnana
    great post. thanks.
