I’m experiencing the exact same problem here:
http://ellislab.com/forums/viewthread/199671/
I have limited ability to troubleshoot (I just have access to the EE CP and templates), so there’s not much I can do except share more details on other problems I’m finding that I suspect is caused by the same issue that’s breaking the search module. Hopefully you can see my description of those issues and confirm exactly what the solution is:
- is running on 1.6.0, I cannot upgrade - limited access as I said, and client does not want to upgrade, they plan to revamp the site entirely in a cleaner, new EE environment
- am getting this error whenever changing admin settings or creating a new template (removing some directory names, leaving the important part):
Warning: Cannot modify header information - headers already sent by .../ee/index.php:2 in .../ee/core/core.functions.php on line 296
The changes do go into effect - ie., a new template is created, the admin settings change, this error is not interfering with my ability to make changes, it’s just spitting out this error message every time.
- when hitting the submit button on search form, it redirects to the home page, with no search information in the URL and the homepage is completely blank. For example, let’s say it’s on acme.com/search and redirect is set to acme.com/results/ but instead it’s going to acme.com/ and loading blank. However, when we go to acme.com by itself, the homepage loads fine.
Hope these details will help pinpoint the exact problem so I can tell the client what to do on the server end.
Elise
