Trouble using image upload
October 22, 2011 2:01pm
  • #1 / Oct 22, 2011 2:01pm
    James Hurst
    We have upgraded our build of EE to
    v2.3.0
    using structure.
    While testing locally we’ve been able to add image to the site, and have migrated the site to the live server. However now if we try and upload an image to the site using the file manager we have a problem. After the image uploads the file manager window shows an error that reads:
    A Database Error Occurred
    Error Number: 1062
    Duplicate entry ‘0’ for key 1
    INSERT INTO `exp_files` (`upload_location_id`, `site_id`, `file_name`, `mime_type`, `rel_path`, `modified_by_member_id`, `uploaded_by_member_id`, `file_size`, `file_hw_original`, `field_1_fmt`, `field_2_fmt`, `field_3_fmt`, `field_4_fmt`, `field_5_fmt`, `field_6_fmt`, `modified_date`, `status`, `title`, `upload_date`) VALUES (‘1’, ‘1’, ‘max_cooper_ep_22.jpg’, ‘image/jpeg’, ‘/srv/curestudio.com/public/htdocs/images/uploads/max_cooper_ep_22.jpg’, 1, 1, 711178.24, ‘997 980’, ‘xhtml’, ‘xhtml’, ‘xhtml’, ‘xhtml’, ‘xhtml’, ‘xhtml’, 1319305303, ‘o’, ‘max_cooper_ep_22.jpg’, 1319305303)
    Filename: models/file_model.php
    Line Number: 229
    I’ve checked the server path in the image upload settings, which seems to be correct, and the directory permissions for the image folder and thumbnail folder are both set to 777.
    The images are being uploaded to the server and i’ve tried a few different files and the error is being thrown everytime (and we can’t use the images in our posts)...
    Anyone got any advice?
  • #2 / Oct 24, 2011 8:05am
    James Hurst
    Is there anyone from Ellis Lab out there? Can you let us know how we should resolve this, it is getting quite urgent -
    Many thanks -
    James
  • #3 / Oct 24, 2011 11:25am
    Mark Bowen
    Hi James,
    Is this an existing site that you have upgraded to 2.3.0 and if so did you have any errors when updating it?
    If there were errors can you please let us know what they were.
    Mark
  • #4 / Oct 24, 2011 11:43am
    James Hurst
    Hey Mark - yes it was an existing site, but there weren’t any errors that I came up during the update. It was updated locally, and we then re-deployed it to a different server (we were migrating the server, which was the reason we went in for the upgrade when we did) - so it is on a different server if that could of caused anything?
    J
  • #5 / Oct 25, 2011 5:25am
    James Hurst
    Hey Mark (or any other Ellis lab’ers out there) any news on this please?
    James
  • #6 / Oct 25, 2011 12:01pm
    Mark Bowen
    Hi James,
    When you deployed the site to the new server did you just import the current database and upload the files or did you use some sort of process such as GIT?
    If you create a new file upload location does that work correctly as you would expect?
    Mark
  • #7 / Oct 25, 2011 12:57pm
    James Hurst
    Hey Mark - not using GIT (or any other deployment process)
    Created a new DB / imported it from our local environment.
    Copied over the files and updated config / Database settings (and a few plug in settings including ImgSizer that needs to know the basepath on the webserver if thats useful)
    I have created a new image upload directory - and tried to upload an image to that directory - but am given an error message that says:
    An Error Was Encountered
    You are not authorized to access this page
    with a back button. It doesn’t upload the image -
    Does that help?
    Thanks for your help!
    Ta
    J
  • #8 / Oct 26, 2011 10:49am
    Mark Bowen
    Hi James,
    Do you have any other member groups in this install that you could try this with or are you using the main super admin account here?
    If not the main super admin account then check that the group has permissions to use the file manager.
    Check for Members > Member Groups > Edit Group (Name of group trying to upload files) > Control Panel Access > Can Access CONTENT: File Manager is set to Yes.
    Mark
  • #9 / Oct 26, 2011 10:50am
    James Hurst
    Hi Mark - i’m using the super admin account -
    J
  • #10 / Oct 26, 2011 10:57am
    James Hurst
    Although worryingly - i’ve just looked at the ‘members’ list and there are three registered ‘members’ that look like some sort of spam / injection. I’ve gone back to look at the build locally, and there were two on there (but a third has crept in) - is something you’ve experienced before? Mysterious members being added?
  • #11 / Oct 27, 2011 10:46pm
    Dan Decker
    Hi James Hurst,
    Let’s get your first issue worked out, then we can have a go at ways you can mitigate spam users and such. When you moved your site, did you make sure to follow the outline here. It provides a list of places to verify your paths. Can you verify that all of your paths on the new server are set correctly?
  • #12 / Oct 28, 2011 1:27pm
    James Hurst
    Hi Dan - I have checked all the paths, and they all look fine. I’ve tried to create another image upload directory but when I add the server path and URL into the settings I’m given the following error, if that helps shed any more light onto the situation:
    Error Number: 1062
    Duplicate entry '0' for key 1
    INSERT INTO `exp_upload_prefs` (`name`, `server_path`, `url`, `allowed_types`, `max_size`, `max_height`, `max_width`, `properties`, `pre_format`, `post_format`, `file_properties`, `file_pre_format`, `file_post_format`, `cat_group`, `site_id`) VALUES ('Images 3', '/srv/curestudio.com/public/htdocs/images/uploads_3/', 'http://curestudio.com/images/uploads_3/', 'img', '', '', '', '', '', '', '', '', '', '', '1')
    Filename: controllers/cp/content_files.php
    Line Number: 2405
    Every time I click submit - i’m shown this error, when I refresh the page it shows me the file upload pref/ dialogue box, without the additional server location details that i’m trying to enter…
    Anything you can do much much appreciated - i’m thinking of starting over again and re-deploying the site from scratch…
    James
  • #13 / Oct 29, 2011 5:48pm
    Dan Decker
    James Hurst,
    Is the site on a server that we would be able to access? If so, be on the lookout for an email from me.
  • #14 / Nov 07, 2011 1:02pm
    Dan Decker
    Hi James Hurst,
    Thanks for working with us in private on this. If you need any further assistance, please let us know in a new thread.
    For the edification of the rest of the community, James’s issue boiled down to compatibility mode in his database export and the use of compression. After some testing to determine the correct compatibility mode and turning off compression, James was able successfully complete the import after disabling compression in his export.
    Cheers!
