URLs created by EE2 are not correct
October 08, 2011 8:57pm
Subscribe [4]
  • #1 / Oct 08, 2011 8:57pm
    teamadna
    I’ve been troubleshooting issues with a site currently under development and am at a loss.  Any URLs created by EE2 are prepending the site url to the full url.
    for example, the css embeds (using the EE css embed code) when rendered on the site the css path is:
    http://www.siteurl.com/http://www.siteurl.com?css=css/style.v.1318119446
    I’ve checked htaccess, index.php, site configuration in CP…..can’t find what’s wrong.  Any guidance would be welcome.
  • #2 / Oct 08, 2011 9:20pm
    Rob Allen
    Can you post your template code that you’re using to generate the stylesheet link?
  • #3 / Oct 08, 2011 9:30pm
    teamadna
    <link rel='stylesheet' type='text/css' media='all' href='{stylesheet=css/style}' />
  • #4 / Oct 09, 2011 11:24am
    teamadna
    Should also note that we are using the multi-language alternative described here:
    http://expressionengine.com/wiki/Multi_language_site_alternative/
    this functionality is working fine, however, just the urls generated by EE are incorrect as initially described above.
    We are running v2.2.2 - Build: date 20110801
  • #5 / Oct 10, 2011 12:40am
    teamadna,
    if you comment out the following does that affect the generated URL?
    $assign_to_config['site_index'] = 'http://www.example.com/en/';
  • #6 / Oct 10, 2011 12:15pm
    teamadna
    Commenting out that line resolves the css embed issue, but now any urls generated by EE don’t include the country path. We are using structure for navigation and now the URLs that it generates are:
    If I’m on the page http://www.sitename.com/en/home
    the url it generates is
    http://www.sitename.com/products
    when it should be be generating
    http://www.sitename.com/en/products
    Before commenting out that line ($assign_to_config[‘site_index’] = ‘http://www.example.com/en/’; in the index.php file located in the en folder) the URLs generated by structure suffered the same fate as the CSS embedded urls, it was creating URLs like: http://www.siteurl.com/http://www.siteurl.com/en/products
  • #7 / Oct 10, 2011 12:23pm
    teamadna
    Update.
    Your suggestion just got me thinking. By changing the URL in the assign_to_config module to just en I was able to get it working.
    So the working line in index.php in the en folder is now:
    $assign_to_config[‘site_index’] = ‘en/’;
    At first blush this appears to resolve the issue.
  • #8 / Oct 10, 2011 2:20pm
    Glad you were able to figure out what the problem was. Don’t hesitate to post again as needed.
