Control Panel Links Missing - EE 1.5
October 08, 2011 2:30pm
  • #1 / Oct 08, 2011 2:30pm
    Eric Nance
    My client came to me with an issue on one of their older domains. It is running version 1.5. They are a Super Admin and no longer can see any of the header links or information in the control panel. Seems like everything after the header displays just fine. There’s just no “logout” button, Publish, Edit, Admin buttons, etc.
  • #2 / Oct 08, 2011 2:32pm
    Eric Nance
    I should also mention that the hosting account they are on doesn’t support the latest version of EE, so unfortunately upgrading is not an option at this time.
  • #3 / Oct 10, 2011 12:30am
    Dan Decker
    HI Eric,
    Do you know if your client’s host made any changes that might be affecting this? Are you aware of any changes that have been made?
  • #4 / Oct 10, 2011 12:31am
    Hi Eric,
    Can your client provide you with a screenshot you can post here?
    Do they have any extensions installed?
    Do they get a browser error?
    What latest version of EE doesn’t the host support EE1.x or EE2.x?
    Can you experience the same issue if you login to the control panel?
  • #5 / Oct 10, 2011 10:58am
    Eric Nance
    Hi John and Dan, thanks for the response.
    I’ve attached a screenshot of the control panel home page.
    Looking at the config.php file, it looks like extensions are enabled but the only one I see in the directory is “ext.file.php”. There are no browser errors that I can see, everything appears to be working correctly, they just don’t have the header buttons in the control panel.
    I tested the hosting server, Liquid Web, for compatibility with EE 2. It says that the version of PHP is incompatible. Looks like the host is on version 4. Contacting tech support they did say that the client is on an older server. They do have newer servers that are compatible but the client is leery of moving things over until the issue is resolved.
    I am not aware of any changes that the host may have done. I’ve confirmed that there is only one Super Admin account, the same account the client uses, and the same login credentials they provided me. Apparently, according to the client, they hired another developer to login and make some updates. What those updates were I don’t know. But, they said that the issue started occurring after the developer made the changes.
    I’m entering this situation late in the game so I’m not really sure of all that has been done. I did a full backup of the files and database just in case.  I’m not familiar with EE 1.5.0 and since it’s such an old version it’s more difficult to find relevant posts in the Forums or issues that may be similar.
    I assume something must have been changed in a core file but I don’t have any older versions of EE to compare it to. The oldest version I’ve ever worked with is 1.6.2.
    I’m also hesitant to do an upgrade without knowing the solution. Seems like going from 1.5.0 to 1.7.1 is a big jump.
  • #6 / Oct 11, 2011 4:21am
    Hi Eric,
    The fact that another dev made changes means we are shooting in the dark here. You need to if at all possible to get in touch with this dev to see what he has changed. Even have a look through the files and check the dates on the remote server to give a clue as to what files may have been changed
    An update to EE1.7.7 would be the recommended route as it would refresh your themes etc but again not knowing what the other dev did may be an issue. Not an issue with the update itself but if the client requested functionality changes and these were done in the core then they would be removed
    Is there any chance of even finding out from your client what they requested from the dev?
    You could also replicate the site locally and do an update there and check everything works ok there
  • #7 / Oct 11, 2011 10:14am
    Eric Nance
    I agree John. The other dev’s work puts a huge variable into play here. Thanks for all the assistance and feel free to close this one out. I’ll try to find out what was changed and do a local upgrade.
  • #8 / Oct 11, 2011 6:34pm
    Dan Decker
    Eric,
    Good luck on your sleuthing! If you need assistance in the future, feel free to start a new thread.
    Cheers!
