Upgrading 2.1.3 to 2.2.2 Causing Errors
October 06, 2011 5:35pm
  • #1 / Oct 06, 2011 5:35pm
    guerilladesigns
    I’ve tried upgrading to 2.2.2 for 2.1.3 several times now and keep getting the same resulting error message.
    My site is hosted on mediatemple.
    Is anyone able to shed some light on this for me? I’ve posted the error message below:
    A PHP Error was encountered
    Severity: Notice
    Message: Undefined variable: DB
    Filename: updates/ud_009.php
    Line Number: 40
    Severity: Notice
    Message: Trying to get property of non-object
    Line Number: 40
    Severity: Warning
    Message: Cannot modify header information - headers already sent by (output started at /nfs/c08/h04/mnt/124312/domains/dev.co-motion.com/html/system/codeigniter/system/core/Exceptions.php:170)
    Filename: core/Common.php
    Line Number: 405
    A Database Error Occurred
    Error Number: 1060
    Duplicate column name 'can_search'
    ALTER TABLE exp_member_groups ADD COLUMN can_search char(1) NOT NULL default 'n'
    Line Number: 112
  • #2 / Oct 07, 2011 3:53am
    Hi guerilladesigns,
    We have a Wiki article titled Troubleshooting Upgrade Errors which I would recommended you run through first.
    Also if you have $conf[‘protect_javascript’] = “n”; in your config.php. Remove it for the upgrade
