Issues with File upload in EE 2.2.2
October 06, 2011 4:40pm
Subscribe [4]
  • #1 / Oct 06, 2011 4:40pm
    Dyad
    I recently upgraded to version 2.2.2 and ever since I’m unable to upload files.
    When I select “Add Image” the file manager is empty.
    When I select “Add Image” a second time nothing happens.
    There is a JS error that gets logged when I try to add an image. I’ve attached screenshots of both.
    I’m aware of an bug that was previously reported but i tried the fixes that were recommended but they did not work.
  • #2 / Oct 07, 2011 3:48am
    Hi Dyad,
    After your upgrade did you synchronize your upload folders?
    To upload a file you need to click Upload File in the top right of that modal window. Does that work for you?
  • #3 / Oct 07, 2011 9:02am
    Dyad
    Yes i tried syncing the file manager but still not working.
    Attached is what my “edit” page looks like. My file upload fields are in a Matrix but I created a simple file upload field without the Matrix and had the same issue.
  • #4 / Oct 07, 2011 9:07am
    Dyad
    The File Manager itself works fine, its the custom field that’s not working.
  • #5 / Oct 09, 2011 10:45pm
    Dan Decker
    Dyad,
    If you take Matrix out of the equation, using the file field on it’s own, do your still see this issue?
  • #6 / Oct 10, 2011 8:53am
    Dyad
    Yes, I tested this out because i had thought that may have been the problem but the problem persists with a stand alone file upload field as well.
  • #7 / Oct 10, 2011 10:20pm
    Dan Decker
    Dyad,
    Have you had the chance to apply this bug fix for the File Manager? If you apply that fix, does this issue persist?
  • #8 / Oct 11, 2011 9:52am
    Dyad
    Yes, i mentioned that in my first post. I also posted a reply in that thread.
  • #9 / Oct 11, 2011 12:26pm
    Mark Bowen
    Hi Dyad,
    The standard file upload field that you are using is that just the ExpressionEngine file field or something else?
    I see in your screenshot above where you are using Matrix that it has a plus icon next to it. I don’t get one of those when using a standard ExpressionEngine file field in my installs so just want to make sure that is what you are using here?
    Mark
  • #10 / Oct 11, 2011 12:37pm
    Dyad
    Yes, my “Test” field uses the standard ExpressionEngine file field.
    I also did a line-for-line comparison of my install and a fresh copy of EE 2.2.2 and can confirm that they matched.
  • #11 / Oct 11, 2011 10:36pm
    Dan Decker
    Hi Dyad,
    We’d like to get in and have a look. Be on the look out for an email from me.
