Assistly Widget Integration?
September 28, 2011 8:38pm
  • #1 / Sep 28, 2011 8:38pm
    Hitch
    Gang:
    Has anyone out there successfully integrated an Assistly contact form Widget (which uses jquery and fancybox) into an EE template?
    My entire site is essentially Boyink’s toots, with a different template.  I have his contact form (http://www.ebookconversion.biz/coffee/contact) as mine; I’d like to substitute the widget.  The widget is essentially simply javascript, but I get whingy about it…if anyone here has successfully done this and has any pointers, I’d appreciate same.
    EDITED TO ADD:  Well, since, as usual, here in the Questions Graveyard, where questions go to die, no one had any thoughts or experience, here’s the code (script tags removed) and here’s my question:
    // ********************************************************************************                                // This needs to be placed in the document body where you want the widget to render                                // ********************************************************************************        new ASSISTLY.Widget({
                                             version: 1,
                                             site: 'sitename.assistly.com',
                                             port: '80',
                                             type: 'email',
                                             displayMode: 1,  //0 for popup, 1 for lightbox                                        features: {
                                              fields: {
                                                    ticket: {
                                                             // desc: '',
                                    // labels_new: '',
                                    // priority: '',
                                    // subject: '',
                                    // custom_book_title: ''
                                                     interaction: {
                                                             // email: '',
                                    // name: ''
                                                     email: {
                                                             //subject: '',
                                                             //body: ''
                                                     customer: {
                                                             // company: '',
                                    // desc: '',
                                    // first_name: '',
                                    // last_name: '',
                                    // title: ''
                                     }).render();
    I’ve already put the script calls in the header, which is an embedded template; at least they’ve not done any harm, as near as I can tell.
    BUT, I either get a blank section of the template whither the widget should be (if I set the type as a webpage), OR a big white Screen O’Death with all the code sitting on it like a text file rendered in a browser if I take a flier and set it as JS.  Obviously, I don’t know what I’m doing, and my EE guy is tied up until mid-November. I’m trying to put the js declarations in the head in ONE template and the actual script in another and kluge them together.  Can anyone—anyone at ALL—provide some pointers?
    Hitch
