Paragraph Tags Appear in None Field set to none
September 28, 2011 4:10pm
Subscribe [4]
  • #1 / Sep 28, 2011 4:10pm
    sleven1868
    EE2.2.2
    I have several templates where paragraph tags are appearing around a text field that is set to none for a channel field group.  Its an image path.  Its weird because it works on some pages and not on others.  Here is an example of the code that is creating a tag around an image.
    <div class = "brand_image_thumb">
     {thumb_image}
    </div>
    When I have just one channel entry in the channel entries tag it puts tags around that image.  When I add another entry, it doesnt put tags around the image which is how it should work because the {thumb_image} field is set to “NONE”.  Is this a bug or can anyone tell me how to fix this?
  • #2 / Sep 29, 2011 3:26am
    hi sleven1868,
    To confirm this is not a custom File field but just a standard custom text input field?
    Are you using any add-ons?
  • #3 / Sep 29, 2011 9:58am
    sleven1868
    It is just a standard text field in ma field group I created for a channel.  I am using Structure and low_seg2cat.  I am not using any low_seg2cat functionality in the template itself.
  • #4 / Sep 30, 2011 10:11pm
    Dan Decker
    sleven1868,
    Can you post the full template where this is being an issue? I would be helpful to see all that is going on.
  • #5 / Oct 11, 2011 12:50pm
    sleven1868
    Sorry for the delayed response.  I’m not getting updates that this thread was updated.  I think its going to spam.
    {embed="embeds/header"}
    <body>
     <div id="left_side">
      {embed="embeds/logo"}
      {embed="embeds/level_three_nav"}
     </div>
     <div id="right_side_pnuru">
      {embed="embeds/global_nav"}
      {embed="embeds/local_nav_top"}
      <div id="content_thumbs">
       <div id="top_description">
        <h2>Personal Electronics</h2><p> <br />
        p.nuru elevates personal electronics to new levels of applied clean power and sophisticated design with the <br />
        firm belief that decreasing environmental impact shouldn’t mean settling for less.<br />
       </div><br />
        {exp:channel:entries channel="pnuru" dynamic="off"}<br />
       <div class="sub_category"><br />
         <a href="http://{path=brands/pnuru_detail/{url_title}}"><div class="brand_summary_thumb">_       <h4 class="brand_thumb_title_pnuru">{title}</h2>_       {short_description}_     </div></a><br />
         <div class = "brand_image_thumb"><br />
          {thumb_image}<br />
         </div><br />
       </div>  <br />
       {/exp:channel:entries}             <br />
      </div><br />
           {embed="embeds/footer"}<br />
     </div><br />
    </body><br />
    </html>
  • #6 / Oct 11, 2011 11:00pm
    Dan Decker
    sleven1868,
    No worries on the delayed response! Can you help us out a little further? What is the content of the custom field {thumb_image}? Just an example from one of your entries will do. I’m interested in seeing what kind of content you are storing there.
  • #7 / Oct 24, 2011 11:54am
    sleven1868
    /images/uploads/brands/qnuru/alma_thumb.jpg
  • #8 / Oct 25, 2011 11:08am
    Kevin Smith
    Hi sleven1868,
    That’s definitely not the expected behavior here. Could you try changing the default formatting on this field to something else, saving, and then changing it back? I recall recently that this action allowed your default formatting selection to stick in the database. If you try this, does it fix the issue?
  • #9 / Oct 26, 2011 5:03pm
    sleven1868
    That is actually what I had to do to fix the issue.  Not sure why its happening.  Its very hard to recreate.  I’ll let you know if it happens again.  thanks
  • #10 / Oct 28, 2011 2:38pm
    Thank you sleven!  I’m glad you have a working solution in the mean-time; I suspect this was caused by an older bug and resetting the formatting as such will fix it going forward.
    if it does reappear, please let us know in a related thread. thank you!
