I’m looking to implement the jquery-ui autocomplete into a site I’m building for a client yet seem to be having some issues.
Here’s the auto complete code:
$.widget( "custom.catcomplete", $.ui.autocomplete, {
_renderMenu: function( ul, items ) {
var self = this,
currentCategory = "";
$.each( items, function( index, item ) {
if ( item.category != currentCategory ) {
ul.append( "<li class='ui-autocomplete-category'>" + item.category + "</li>" );
currentCategory = item.category;
self._renderItem( ul, item );
$(function() {
$("input[name=keywords]").autocomplete({
delay : 0,
source : "{site_url}_shared/autocomplete/"
});This doesn’t work. However, if I remove the source and change it to: “search.php” it does.
Both the autocomplete template and search.php contain the following:
<?php
$data = array(
array(
'label' => "anders",
'category' => "",
array(
'category' => "",
array(
'label' => "antel",
'category' => "",
array(
'label' => "annhhx10",
'category' => "Products",
array(
'label' => "annk K12",
array(
array(
'label' => "annttop C1",
array(
array(
'label' => "anders andersson",
'category' => "People",
array(
'label' => "andreas andersson",
array(
'label' => "andreas johnson",
echo json_encode($data);
?>PHP parsing is turned on for the template…
I’m not sure what could be causing this. If i actually navigate to the URL the template resides at it displays the data and jslint returns the data as valid json.
If anyone has any ideas it would be appreciated.
