Memory leak in the EE Codeigniter XML-RPC?
September 12, 2011 7:50am
  • #1 / Sep 12, 2011 7:50am
    Citylogic
    I have been getting the following:
    Fatal Error: Allowed memory size 0f 33552232 bytes exhausted (tried to allocate 96 bytes) in ..(path) on line (line)
    The path varies and line number varies.
    I am concerned by the following codeigniter post:
    http://ellislab.com/forums/viewthread/143001/
    And that this may be an inherited fault in expressione engine running on codeigniter and causing the problem.
    Can you confirm that this is not in fact the case and that XML-RPC in the codeigniter folder does not suffer from this problem?
    Thank you,
    Aidan Classe.
  • #2 / Sep 12, 2011 6:10pm
    Kevin Smith
    Hi Aidan,
    I’m not concerned about the post in the CodeIgniter forum mostly because of its age. There are currently no outstanding issues concerning XML in the CI GitHub Issues tracker, so it doesn’t appear that anyone is still experiencing that issue.
    Perhaps you could give us more information about the issue you’re experiencing? Is it something we should be able to reproduce on our end? Is it something that’s consistent every time for you?
