Display entries by current month from Date Field
September 10, 2011 9:56am
  • #1 / Sep 10, 2011 9:56am
    richardmeredith
    Hi, I’m wondering if it’s possible to display entries by current month from a date channel field.
    Basically they are adding about 2 months worth of data at once so can’t go by the publish date.
    Fingers crossed!
    R
  • #2 / Sep 11, 2011 12:33am
    LMO
    Here is a sample php script that will grab the entry_ids for the current month of a custom field. You will need to find the custom field_id of the date field. Set PHP to input and add the field_id and channel_id to the variables at the top.
    <?php
        $channel = 3;
        $field = 'field_id_5';
        function implode_r($glue, $pieces)
            $return = "";
            if(!is_array($glue)){
                $glue = array($glue);
            $thisLevelGlue = array_shift($glue);
            if(!count($glue)) $glue = array($thisLevelGlue);
            if(!is_array($pieces)){
                return (string) $pieces;
            foreach($pieces as $sub){
                $return .= implode_r($glue, $sub) . $thisLevelGlue;
            if(count($pieces)) $return = substr($return, 0, strlen($return) -strlen($thisLevelGlue));
            return $return;
        $this->EE =& get_instance();
        $month_start = mktime(0, 0, 0, date("m")  , 1, date("Y"));;
        $month_end = mktime(0, 0, 0, date("m")+1  , 1, date("Y"));;
        $results = $this->EE->db->select('titles.entry_id')
                    ->from('exp_channel_titles as titles')
                    ->join('exp_channel_data as data', 'titles.entry_id = data.entry_id')
                    ->where("$field >= $month_start")
                    ->where("$field < $month_end")
                    ->where('titles.channel_id',$channel)
                    ->get()
                    ->result_array();
        $ids = implode_r("|", $results);
    Then just add a simple echo to the entries loop.
    {exp:channel:entries
        channel="data"
        entry_id="<?php echo $ids; ?>"
  • #3 / Sep 11, 2011 9:45am
    richardmeredith
    Ended up going with Solspace Calendar to display the events but will give this a whirl also.
    Thanks again, much appreciated 😊
    Rich
