plugin system
September 04, 2011 5:15pm
Subscribe [5]
  • #1 / Sep 04, 2011 5:15pm
    predat0r
    Anybody has some material on “Add-on development with Codeigniter” by Adam Fairholm ?
    EDIT: finally I solved it , made a simple plugin system for my cms
  • #2 / Sep 25, 2011 1:59am
    Timothy_
    Hi there,
    I am also trying to figure out how to make a simple plugin system for an application I am writing.
    Are you willing to share your code? Does anyone else have a good plugin system?
    Tim
  • #3 / Sep 25, 2011 7:31am
    predat0r
    I used this library to build my simple plugin:
    https://github.com/bl00dshooter/Plugin-Codeigniter-Library
    You can grab from the example how it works..
    But if not, how it works for me, in short?
    If a plugin is enabled, register an event, then trigger it in a special place in you code. Event is a function in your plugin’s code.
    I’ve made a config file, with plugin name, desc, version, position (left), and an array of parameters - info, the controller reads this into the DB, and stores.
    On an admin page you can enable/disable the plugins.
    In your left colunm view you trigger the ‘left’ event, so the enabled plugins, and where positions set to left will show up in your left column.
  • #4 / Oct 02, 2011 4:50am
    Vheissu
    I wrote a plugin system myself for Codeigniter. I based it on how Wordpress’s plugin system works. It might require some tweaks to accommodate peoples tastes, but it works and I use it in all of my personal projects.
    https://github.com/Vheissu/CI-Plugin-System
  • #5 / Oct 02, 2011 11:46am
    predat0r
    Great library! Can you tell me how could you implement the following simple plugin task: i have a twitter plugin, that outputs 5 twitter feeds. Switching on/off the plugin on frontend works.
    1. How do you skin the plugin with css, where do you place the css?
    2. How do you handle on an admin page the feed’s username, and count? How do you validate the input fields in the plugin system? (Of course I dont ask about CI form validation..).
    Is it a solution to split a plugin to frontend and backend part, what do you mean?
    Thanks 😊
  • #6 / Mar 18, 2012 7:11am
    vee
    there are errors:
    A PHP Error was encountered
    Severity: Notice
    Message: Object of class CI could not be converted to int
    Filename: libraries/Plugins.php
    Line Number: 60
    Severity: Notice
    Message: Trying to get property of non-object
    Line Number: 62
    Fatal error: Call to a member function database() on a non-object in application\libraries\Plugins.php on line 62
    codeigniter 2.1.0
    just load library plugins. not call method/function/or anything
