{exp:file:entries} count
September 01, 2011 12:34am
  • #1 / Sep 01, 2011 12:34am
    Ryan
    I’m having trouble outputting the {count} for each entry output;
    {exp:file:entries directory_id="1"}
        {if viewable_image}<li id="image_{count}">{file_url}</li>{/if}
    {/exp:file:entries}
    The problem is each <li> is being returned with the ID image_1, isn’t this supposed to be incremental?
    On a related note, in the File Manager (v2.2.2) the “Upload File” link href is blank and just reloads the page for me.
    I thought it used to display the “Upload File” popup form.
  • #2 / Sep 01, 2011 11:37am
    Hi Josephs,
    The problem with the File Manager not displaying is a known bug, you can find a workaround for it at:
    https://support.ellislab.com/bugs/detail/16322/
    I can’t replicate the problem you were having—see the attached partial screen shot.
  • #3 / Sep 01, 2011 11:42am
    Ryan
    Thanks for confirming that Sue, I’ve realised the problem is with my code.
    The {exp:file:entries} pair is inside a {exp:channel:entries} pair, hence {count} is referencing the channel and not the files.
    I had done this is because of a conditional; to display {exp:file:entries} whether a value in {exp:channel:entries} is set.
    {exp:channel:entries channel="example" limit="1"}
        {if files}
            <ul>
            {/exp:file:entries}
            </ul>
    Any idea how I can separate the two and still have the condition?
  • #4 / Sep 02, 2011 12:55am
    Dan Decker
    Josephs,
    You could try replacing {count} with {entry_id}
    {if viewable_image}<li id="image_{entry_id}">{file_url}</li>{/if}
    That would still give you a unique id for each image.
  • #5 / Sep 02, 2011 6:13am
    Ryan
    You could try replacing {count} with {entry_id}. That would still give you a unique id for each image.
    Bah, {entry_id} seems to be a {exp:channel:entries} variable too :down:
  • #6 / Sep 02, 2011 3:01pm
    Hi, Josephs -
    did you try embedding the file entries tag to avoid the variable conflict?
  • #7 / Sep 02, 2011 8:36pm
    Ryan
    Did you try embedding the file entries tag to avoid the variable conflict?
    Hi Lisa, no I actually noticed that in the {exp:file:entries} tag, I’m actually setting the directory_id with a variable from {exp:channel:entries} as well.
    Plus I needed the conditional from {exp:channel:entries} as well.
    This isn’t the first time this has happened, like for example with {exp:comment:entries}  I’ve wanted to use {exp:channel:entries} {if allow_comments} conditional, and have not found a way to separate the tag pairs.
    Fortunately with the {exp:file:entries}, this time I was able to achieve what I needed with a different method; using jQuery!
  • #8 / Sep 02, 2011 9:33pm
    You would need to pass the directory_id through the embed.  Then you can embed and avoid the problems you are running into.  Make sense?  So:
    {embed='blah/blah' my_var="3"}
    then in the calling template:
    {exp:file:entries directory_id="{my_var}"}
  • #9 / Sep 08, 2011 1:14am
    Ryan
    Thanks Lisa, I’m using an embed now. I thought I tried this before, but I must have missed something!
  • #10 / Sep 08, 2011 11:46am
    Glad you got it working, Josephs!  if you do have anything else come up, please let us know and we can help out.
    Thank you!
