Is it possible to determine in a template if it’s loaded via an ajax-request or not? The reason is to deliver different templates for each kind of request.
August 30, 2011 2:34pm
Subscribe [3]#1 / Aug 30, 2011 2:34pm
#2 / Aug 31, 2011 3:07am
Hi thomasaull,
Can you give some more context and an example of what you are trying to achieve here please.
What types of requests other than ajax are you referring to?
#3 / Aug 31, 2011 5:08am
I’m trying to implement a live search function for my Blog on http://www.thomas-aull.de/blog
The tricky part is, that the template path to my search results is fixed in my exp:search:simple_form Tag. I can’t change it later in my ajax request, it simply doesn’t work.
However, i need different output for a search request via ajax and a normal search (if someone has javascript disabled for example).
So, the idea was, to determine inside the template if the request is via ajax.
Do you get my problem?
#4 / Sep 01, 2011 11:50am
Hi thomasaull,
There is no built-in method in ExpressionEngine to determine if a page was loaded by Ajax however I do know of a plugin MX Ajax Detect which is reported as working on ExpressionEngine 2.x
Does that help at all?
Mark
#5 / Sep 01, 2011 11:52am
I’ll try this out asap!
#6 / Sep 01, 2011 12:15pm
Ok i tried the MX Ajax Detect Plugin. Basically it works fine, but unfortunately when i try to use it for my live-search it don’t. I think it’s because there is a redirect or anything and so the HTTP-Header “HTTP_X_REQUESTED_WITH” = XMLHttpRequest” gets lost…
Any chances for another solution?
#7 / Sep 01, 2011 1:00pm
I think this post is moving more into a how-to now as there isn’t anything built-in to ExpressionEngine that will allow for this to be done I’m afraid.
You could contact Max about that plugin as he is a very approachable / knowledgeable chap and so might be able to help out further with the problems you’re having.
Other than that I think that this post would be best suited to the Community Help forums to see if anyone else has ever done this sort of thing.
Would you like me to move the post there for you?
Thanks.
Mark
#8 / Sep 01, 2011 1:10pm
Yes please move it for me, thanks!
#9 / Sep 01, 2011 2:11pm
Et voila! 😉
Hopefully someone will be able to help out here on this one although I’d still recommend contacting Max as he’s really good at those sorts of things.
