Hi
I need to add a couple of constants for use throughout my current build - is it generally better practice to add these to the constants.php config file? or elsewhere?
Thanks.
August 28, 2011 5:34am
Subscribe [2]#1 / Aug 28, 2011 5:34am
Hi
Thanks.
#2 / Aug 29, 2011 3:32am
Hi Lee,
Are you developing an add-on?
Is this just for general template use?
If for use in your templates then I would recommend a Global Variable_. Would that be sufficient? If not can you give us some context to your need for a new Constant?
