From 2003 on I am a user of pm/EE. I am very pleased with what the software offers but I did not use it very extensively and did not bother to upgrade. So I am still working with a very old version/build: 1.6.8.
Now I want to move my site to another server. And get into some problems. I follow the instructions on moving that I found among the frequently asked questions. After moving the database and the files and after changing some settings step 8 tells me to login (tot the control panel) but I cannot. (‘username nog found in database’). Beside that I see there is something wrong with the theme (there is no CSS active, so it seems).
The note from the frequent questions tells me to upgrade after moving, but I wonder if this advice applies to my situation too. A lot has changed by now (my templates still use ‘weblog’ instead of ‘channel’ for example). I am aware of the fact that I have been kind of penny-pinching and probably I really should upgrade by now but. Hence my question: is it wise to upgrade after moving when you are still using a really old version? (it does everything I want it do do, with very minor setbacks).
[Mod Edit: Moved to the ExpressionEngine 1 Technical Support forum]
