Incremental class or IDs
August 22, 2011 11:20am
  • #1 / Aug 22, 2011 11:20am
    MadhouseHQ
    Hello,
    I have an list of items for which I need a unique class name on each <li>.
    Currently I have something like:
    <ul>
    {exp:channel:entries}
    <li><a href="http://" class="itemN">This is a {custom_field}</a></li>
    </ul>
    This gives me my list but with ALL classes as ‘itemN’ where ‘N’ needs to be an incremental number (item1, item2, item3 etc…).
    Can this be done?
  • #2 / Aug 22, 2011 11:24am
    Fusion Design
    Hi there,
    You should be able to use the count tag to do this
    <ul>
    <li><a href="http://" class="item{count}">This is a {custom_field}</a></li>
    </ul>
    Hope this helps.
  • #3 / Aug 22, 2011 11:36am
    MadhouseHQ
    Ahhh… This works great except with Matrix.  I probably should have mentioned I was using Matrix :(
  • #4 / Aug 22, 2011 11:42am
    Fusion Design
    Matrix uses the {row_count} tag instead, does that help?
  • #5 / Aug 22, 2011 11:43am
    MadhouseHQ
    Yes, yes it does!  Thanks again!
  • #6 / Aug 22, 2011 11:44am
    Fusion Design
    Glad you could get it sorted!
