I set up a log for slow queries.
Here is one that was just logged, I checked my system memory usage on the server and it spiked, probably due to this query, not sure what page was being accessed when it ran this query, but I am guessing it was within the CP since it references member tables.
SELECT t.entry_id, t.weblog_id, t.forum_topic_id, t.author_id, t.ip_address, t.title, t.url_title, t.status, t.dst_enabled, t.view_count_one, t.view_count_two, t.view_count_three, t.view_count_four, t.allow_comments, t.comment_expiration_date, t.allow_trackbacks, t.sticky, t.entry_date, t.year, t.month, t.day, t.edit_date, t.expiration_date, t.recent_comment_date, t.comment_total, t.trackback_total, t.sent_trackbacks, t.recent_trackback_date, t.site_id as entry_site_id,
w.blog_title, w.blog_name, w.blog_url, w.comment_url, w.tb_return_url, w.comment_moderate, w.weblog_html_formatting, w.weblog_allow_img_urls, w.weblog_auto_link_urls, w.enable_trackbacks, w.trackback_use_url_title, w.trackback_field, w.trackback_use_captcha, w.trackback_system_enabled,
m.username, m.email, m.url, m.screen_name, m.location, m.occupation, m.interests, m.aol_im, m.yahoo_im, m.msn_im, m.icq, m.signature, m.sig_img_filename, m.sig_img_width, m.sig_img_height, m.avatar_filename, m.avatar_width, m.avatar_height, m.photo_filename, m.photo_width, m.photo_height, m.group_id, m.member_id, m.bday_d, m.bday_m, m.bday_y, m.bio,
md.*,
wd.*
FROM exp_weblog_titles AS t
LEFT JOIN exp_weblogs AS w ON t.weblog_id = w.weblog_id
LEFT JOIN exp_weblog_data AS wd ON t.entry_id = wd.entry_id
LEFT JOIN exp_members AS m ON m.member_id = t.author_id
LEFT JOIN exp_member_data AS md ON md.member_id = m.member_id WHERE t.entry_id IN (942) ORDER BY t.sticky desc, t.entry_date desc, t.entry_id desc;# Time: 110816 11:04:30
# User@Host: db_username[db_username] @ localhost []
# Query_time: 16 Lock_time: 0 Rows_sent: 0 Rows_examined: 1868702269
# administrator command: Init DB;Seems like 1868702269 rows it way too many.
v1.7.1 build 20110509
Ran the query manually, returned one record within 6.9 ms, so it seems like that is not the culprit.
This query was just logged:
SELECT DISTINCT ee.* FROM exp_extensions ee WHERE enabled = 'y' ORDER BY hook, priority ASC, class;I am the only one with a super admin account and I did not load the extensions or any utilities within the CP. Could this query run on the front end of the site, when a visitor views a webpage?
Also, I’ve seen some more exp_security_hashes table queries coming in, such as:
INSERT INTO exp_security_hashes (date, ip_address, hash) VALUES(UNIX_TIMESTAMP(), '184.8.187.4', 'ef8de60db6e1faed1ff6cacb50e4e50c894074b5');This just came in as well,
SHOW FULL COLUMNS FROM `exp_message_copies` FROM `expression_engine`;Another came in
SHOW TABLES FROM `expression_engine` LIKE 'exp\_%';Not familiar w/ these queries, as to whether they should be running within the CP or front-end when the user views a regular old webpage.
The last query I posted looks like someone is trying to find out more about the database structure. No super admin was using the CP when this query ran.
