Entry Status Not Saving
August 15, 2011 3:15pm
  • #1 / Aug 15, 2011 3:15pm
    Loquela
    I have created a Custon Member group with an associated member.
    This group has permissions to edit channel A. On the Edit Entry page under Options the Status dropdown is available and statuses Open and Closed are present.
    The member is able to change the status from Open to closed and this saves no problem.
    However, this user is unable to change the status back from Closed to Open. When trying to do so, the system dosplays the message Entry Has Been Updated. But in fact it hasn’t and the status remains closed.
    Please advise.
    Kind regards,
    L.
  • #2 / Aug 16, 2011 3:29am
    Loquela,
    This behavior occurs when you have not set selected a status group for your Channel. Set that and it should work for you
