Custom Pagination Positioning
August 11, 2011 7:06pm
  • #1 / Aug 11, 2011 7:06pm
    Mattias01
    Hi guys,
    I did have a dig around but couldn’t really find a EE2 solution for this…
    I have a list of entries.
    I only want to display x amount of entries, then add a next/prev link to load the next x amount of entries.
    I can do this with pagination. But how do I position the pagination so a ‘previous’ link appears in the list before my entries and a ‘next’ link appears after them?
    In case your wondering why I’m doing this; I’m building an image carousel so the next and prev links would become arrows.
    thanks
    Matt
    Moved to Community Help forum by Moderator
  • #2 / Aug 11, 2011 7:59pm
    joni^
    as you can give your prev and next links different classes, you can style/position them via css. just use a wrapper div with position:relative; and place your links with position:absolute;
    would that work for you?
  • #3 / Aug 11, 2011 8:36pm
    Mattias01
    Yeah I have done it like that in the past, however this layout was a little trickier so it would have gotten messy, however I did find a solution.
    I used this plugin:
    MX Jumper
    http://www.eec.ms/add-ons/mx-jumper
    And here’s my code, I have built a thumbnail gallery with this, with next and prev arrows using pagination, here I’ve stripped out all my images etc to make it easy to read….
    <ul>
    {exp:mx_jumper:out_global}
        {exp:channel:entries channel="my-channel" limit="10" paginate="bottom"}
            {paginate}
                {exp:mx_jumper:put name="pagination_prev"}
                    {if previous_page}
                        <li><a href="http://{auto_path}">Previous</a></li>
                    {/exp:mx_jumper:put}
                           {exp:mx_jumper:put name="pagination_next"}
                          {if next_page}
                        <li><a href="http://{auto_path}">Next</a></li>
                   {/paginate}
        <!-- this puts in the previous pagination link -->
        {pagination_prev}
        <!-- here's the entries -->
            <li><a href="http://{title_permalink=mypath/}">{title}</a></li>
        <!-- this puts in the next pagination link -->
        {pagination_next}
    {/exp:mx_jumper:out_global}
    </ul>
    hopefully thats some help to anyone trying to achieve the same thing
  • #4 / Aug 11, 2011 9:08pm
    Mattias01
    I think it still needs some work though,
    it seems to repeat the pagination links
  • #5 / Aug 12, 2011 9:58am
    Hi, mattias78. Since you’re working with third party code, let’s move this over to the Community Help forum for additional community support.
  • #6 / Aug 12, 2011 1:26pm
    Mattias01
    Thanks Sue,
    I’m working on this with Max over here
    http://www.eec.ms/forums/viewthread/235/
