uncategorized_entries not what I thought?
August 11, 2011 5:44pm
  • #1 / Aug 11, 2011 5:44pm
    municipal
    I’m having difficulty grasping the docs when it comes to categories. Is there a way to ONLY output the entries in a weblog that have NOT been assigned to a category?
  • #2 / Aug 12, 2011 6:26am
    hi municipal,
    You need to use 2 parameters to do that. category_group= and uncategorized_entries=
    You will need to add the category group ID(s)s to the category_group parameter that you do not wish to show.
    {exp:channel:entries channel="about" category_group="not 1" uncategorized_entries="yes"}
    Let me know if that works for you
  • #3 / Aug 12, 2011 6:39am
    municipal
    Sorry—left out that I was trying to accomplish this dynamically and thus, without having to specify any weblog/category group. So it cannot be done??
  • #4 / Aug 12, 2011 6:49am
    municipal,
    You don’t need to specify the channel but you will need to use the other 2 parameters to do what you wish.
    You could experiment with the categories tag pair also
    {exp:channel:entries dynamic="no"}
    {categories}
    {if category_id == ''}
    {title}
    {body}
    {/categories}
  • #5 / Aug 12, 2011 7:09am
    municipal
    I’m not sure I understand what your suggested code with the categories pair is supposed to do and how to use it? I mean, I tried and it doesn’t output anything.
  • #6 / Aug 15, 2011 4:03am
    municipal,
    My logic there isn’t going to work unfortunately.
    The only way that can be accomplished is using my original method from the docs using the parameters
