Hello All,
Would there be a reason why when writing an entry into the Textarea of a custom fields for a channel, that the tags would just disappear. Half way through the entry?
Essentially the text is being formatted correctly, and then the system ceases to wrap text in tags.
This revealed when I inspect the source through Safari or Mozilla of the rendered entry.
I have <h1>, <h2>, <h3> as well as <ul> in the entry. Some <strong> as well. All of which I use through the formatting buttons while writing either in “write mode” or simply in the regular Textarea in the “edit entry” screen.
The Textarea is set to accept XHTML be default.
This one has me baffled, particularly when previous entries work just fine.
Thank you.
I am currently running the basic install - no third party add-ons.
v2.1.3 - Build: 20101220
