Multiple not IS_EMPTY parameters on channel:entries
August 10, 2011 12:58pm
  • #1 / Aug 10, 2011 12:58pm
    Jon @ Kernel
    Just a quickie - is there any way to use this on multiple custom fields:
    search:custom_field="not IS_EMPTY"
    So, if either file_relationship_event OR file_relationship_conference have content, then show the entry:
    In mangled EE code:
    {exp:channel:entries channel="memberarea" orderby="date" dynamic="off" search:file_relationship_event="not IS_EMPTY" OR search:file_relationship_conference="not IS_EMPTY"}
        {title}
    Alternatively, if this needs the query module - any tips on code for that one?
  • #2 / Aug 11, 2011 4:48am
    Hi Jon,
    Is it a standard relationship field or Playa or similar?
    You could just use a conditional for the existence of a 0 value which is the default for a relationship field
    {exp:channel:entries channel="memberarea" orderby="date" dynamic="no"}
        {if file_relationship_event != '0' OR file_relationship_conference != '0'}
         {title}
    Does that help?
  • #3 / Aug 11, 2011 12:48pm
    Jon @ Kernel
    Thanks John - It’s 2 Playa fields, actually.
    I hadn’t thought of that because I only want to output 1 entry (limit=1), and show the entry (an event/conference) the resource in the memberarea channel is related to so figured that would be quite an inefficient of doing it?
    Since not every entry in memberarea holds a relationship with an entry, I can’t use ‘limit=1’ on the channel entries tag with that method, as the first entry might not hold a relationship.
    Essentially, we’re looking to:
    Show first entry in channel="memberarea" where file_relationship_event OR file_relationship_conference !="" and only output 1 result for this query
  • #4 / Aug 13, 2011 5:35pm
    Dan Decker
    Hi Jon,
    In the scenario you describe, you might have to let {ep:channel:entries} retrieve more than 1 entry, and then apply your logic via John Henry’s suggested conditionals, and then use Playa’s limit parameter to achieve the results you are looking for. However, I have no experience with Playa so that’s all conjecture on my part, after reading through the Playa docs.
  • #5 / Aug 14, 2011 9:09pm
    Jon @ Kernel
    Thanks guys - we fiddled around with things a little bit and simplified the process a bit.
    The queries were a bit too memory intensive to be worth it, really, but we do at least have something that does the trick, based on a little bit of your suggestion, John!
  • #6 / Aug 15, 2011 4:09am
    Good stuff! Feel free to start a new thread if you have any more questions.
