Hi John
What version and build of both EE and MSM are you using?
2.1.3 20101220 - MSM Version: 2.0 Build: 20101215 No its not the latest version but i am still over 4 weeks into trying to get another site to work with the latest version so will not be updating this one.
Are you using any add-ons?
yes
Firemail 1.7.2
Freeform 3.0.5
Sitemap 2.2.1
Sl_developer_info 1.0.0
Shortcut 1.1.1
Mountee 2
Nsm_live_look 1.1.2
Hits 2.0
Nsm_better_meta 1.1.2
Key_search 1.3
Taggable 1.4.5
M62_backup 1.6.2
Matrix_multi_upload 0.9.1
Can you explain what you did to set-up each site? Did you duplicate the sites or make blank MSM sites?
Made blank sites
Is each site a different domain or a different folder?
Each site is a different domain with a different folder on Engine hosting this is there set-up.
What did you change in each admin.php for each site?
I change the $assign_to_config[‘cp_url’] file to the domain name plus admin name. Each folder has a admin.php file, index.php file and a path.php file plus a .htaccess file in a folder.
What are you using for the Control Panel Session Type under Security and Session Preferences
cookies only
