How to create template variables?
August 02, 2011 7:18pm
  • #1 / Aug 02, 2011 7:18pm
    opel
    I am using the CE image plugin inside an {exp:query tag} but having a problem. CE requires a tag with a complete url path, however the SQL result only pulls back the file name, for some reason it does not parse the {file_dir3} that is stored in the database cell.
    What I am trying to do inside the exp tag is basically to append the fill path on to the select result, and create a new variable that I can put into the CE tag parameters.
    My code is below but not sure what I’m missing, any help please. I tried the preload tag thats in the manual but with no joy.
    {exp:query limit="5" pagination="bottom" sql="SELECT t.entry_id, t.title, t.url_title, d.field_id_7 AS event_summary, d.field_id_8 AS event_date, d.field_id_9 AS event_flyer, d.field_id_10 AS event_facebook FROM `expsc_channel_titles` AS t NATURAL JOIN `expsc_channel_data` AS d WHERE d.channel_id = 3 AND CAST(d.field_id_8 AS UNSIGNED) >= (unix_timestamp(Now())) - 86400 ORDER BY d.field_id_8 ASC"}
        {if no_results}
        <strong>There are no events at the moment but there will be soon.</strong>
            <h2>{title}</h2>
    <p>        {exp:ce_img:single src="{event_flyer}" max="300" allow_scale_larger="yes"}<br />
            {exp:ce_img:pair src="/images/events/{event_flyer}" width="200" height="130" crop="yes" }<br />
            <a href="http://{made_url}" title=" View {title} photo">_            {made}_        </a><br />
            {/exp:ce_img:pair}
  • #2 / Aug 03, 2011 12:06am
    LMO
    Hi opel,
    A quick search on devot-ee.com returned this plugin: http://devot-ee.com/add-ons/parse-filedirectories
    Looks like this should help you with your issue.
  • #3 / Aug 03, 2011 8:47am
    Thanks for the assist, VIM Interactive.
    opel I’ve also created global variables for {file_dir1} and the like. What ever works for you. Let us know!
