No search results ("Template group and template not found, showing 404 page")
August 01, 2011 7:26am
Subscribe [6]
  • #1 / Aug 01, 2011 7:26am
    Jolantis
    I didn’t try out search since I updated from 2.1.3 tot 2.2.1. But now search doesn’t give results anymore, but shows the 404 page.
    When I turn on template debugging I could see the following was happening:
    (0.000004 / 7.42MB) - Begin Template Processing -
    (0.000107 / 7.42MB) URI: search/results/399b4848cf4edb4e2382ef3c099f3e22
    (0.000116 / 7.43MB) Path.php Template: /
    (0.000124 / 7.43MB) Retrieving Template
    (0.000130 / 7.43MB) Parsing Template URI
    (0.002179 / 7.71MB) Template group and template not found, showing 404 page
    (0.002191 / 7.71MB) Retrieving Template from Database: /
    (0.002502 / 7.71MB) Template Found
    (0.002549 / 7.72MB) Retrieving Template from File
    (0.002721 / 7.71MB) Template Type: 404
    (0.002735 / 7.71MB) Parsing Site Variables
    So the search/results template is not found?! Off course it’s there.
    And looking to the DB queries shows the following:
    0.0002  SELECT `group_id`
                 FROM (`exp_template_groups`)
                 WHERE `group_name` =  'search'
                 AND `site_id` =  '1'
    0.0003  SELECT exp_templates.template_name,
    But when I look to the DB queries of an older installation (version 2.1.3) that I’ve still running, and for which search is working, I see the following:
    0.0003  SELECT `group_id`
                AND `site_id` = '1'
    0.0002  SELECT COUNT(*) as count
                 FROM (`exp_templates`)
                 WHERE `group_id` = '8'
                 AND `template_name` = 'results'
    If I look in the DB (exp_search), I can see there are really results (see attached screenshot). And I did not change the search (results and no results) templates between the 2.1.3 and 2.2.1 update!
    I saw the search module is updated with EE 2.2.1 from 2.0 to version 2.1? Has something been changed that results in this behavior?
    Any ideas, help? I’m testing it still locally, but I could put it on a server if that helps?
  • #2 / Aug 01, 2011 5:44pm
    Kevin Smith
    Hi Jolantis,
    Be on the lookout for an email from me. This certainly is strange behavior, and we want to get it taken care of.
  • #3 / Aug 02, 2011 11:51am
    Jolantis
    Hi Kevin,
    I’ve send you the information via the provided link in the email.
    The site is nog yet “on” ($config[‘is_system_on’] = “n”), so make sure to login first to be abel to see the site.
    The link to the search page is http://stage.artlantis.nl/search
  • #4 / Aug 03, 2011 4:07pm
    Kevin Smith
    Hi Jonathan,
    Glad to hear that you already upgraded to 2.2.2! Since upgrading, are you still experiencing this problem? In trying to run tests, I’m not seeing the 404 page.
  • #5 / Aug 03, 2011 4:20pm
    Jolantis
    Hi Kevin, I noticed this too, but I still do get the 404 on my local dev machine. But although I don’t get the 404 page on the staging server, I don’t get results either. No matter what I search for (titles I know exist), I always get the no results message?!
    But there is a difference between the local and staging server…
  • #6 / Aug 03, 2011 6:32pm
    Kevin Smith
    If there EE installation and DB are exactly the same on local and staging servers, then it’s probably a server issue locally causing the 404. Strange…
    Let me hop back in there and see if I can figure out why the search isn’t returning results…
  • #7 / Aug 04, 2011 5:08pm
    Sent along a longer reply- but see if it’s working for you now.
  • #8 / Aug 08, 2011 12:53pm
    Hi Jolantis - have you had a chance to check yet?
  • #9 / Aug 09, 2011 6:13pm
    Brandon Jones
    Just checking in again, Jolantis.
  • #10 / Aug 11, 2011 11:35am
    Marcus Neto
    Closing this issue due to no response. Jolantis, if you run into another issue please don’t hesitate to post again.
