Multi-Lingual Site: Arabic and Chinese characters getting removed on entry submit.
July 06, 2011 1:49pm
Subscribe [4]
  • #1 / Jul 06, 2011 1:49pm
    Nate Iler
    I’ve created a multi-lingual channel where my custom fields are setup as follows:
    description_en - English description
    description_fr - French description
    description_ar - Arabic description
    description_ch - Chinese description
    When I populate the fields with their proper language, the Arabic and Chinese content gets stripped out of the fields and doesn’t get saved.  The English and French text saves fine.  It looks like the special letter characters are causing the problem.  Has anyone encountered this issue before?
    Test Code:
    description_en - Hello Sir
    description_fr - bonjour monsieur
    description_ar - مرحبا يا سيدي
    description_ch - 你好先生
    EE 2.1.3 build:20101220
    php 5.3
    mysql collation: utf8_general_ci
  • #2 / Jul 06, 2011 1:54pm
    Nate Iler
    Well, I did some further testing and when I downgraded PHP to version 5.2.17 all languages saved correctly.  Does anyone know what the issue is with PHP 5.3.5?
  • #3 / Jul 07, 2011 7:00am
    Hi Nate,
    What type of custom fields were they?
    Is this on MAMP or a live server
    Can you try the following suggestion please
    Can you open config.php and set
    $config['charset'] = "utf-8";
    (make it lowercase) and see if that has any affect?
  • #4 / Jul 28, 2011 4:57pm
    Intersindical
    At least, it helped to me. I was having the same issue.
    Many thanks.
  • #5 / Jul 28, 2011 5:19pm
    Brandon Jones
    Glad to hear, Intersindical!
    Did that help Nate?
