Hiya,
Hopefully an obvious answer to this one that I’m just missing due to not having had any sleep for the past 72 hours!
I have been re-designing a site for a client and they just pointed their A-Record for www across to our server. All fine and dandy. I updated the domain administrator from the development domain name of example.ourserver.com to their domain name example.com and everything went wrong with that as Plesk reported that I only had 2MB of webspace being used whereas there was actually over 450MB.
To get around this I renamed that domain back again and created a brand new one. I then uploaded all the backed up FTP files, created a brand new database with completely different login credentials and changed the information in the config.php file to reflect this.
Now when I visit the control panel to login it is un-styled as I would expect it to be as paths are not yet right however if I try to login it won’t let me. I just get the message :
The username you submitted was not found in the database
I’ve checked now around 20 times and it most definitely is in the database and I am putting it in correct to the control panel login fields but it just keeps on coming up with the same message every time.
I’ve never had this problem before when copying files and databases across before so this has really got me stumped although as I mentioned it could be due to the lack of sleep.
Any help on this though would be massively appreciated as this is a site for a very large American company and it needs to go live by Monday so time is most definitely of the most importance on this one I’m afraid.
Thanks for any help on this.
Best wishes,
Mark
