Hello,
I recently moved an older site (v1.6.7) to a new server, and after I did, the whole CP would appear blank after log-in. I narrowed it down to the extensions, so I set the
$conf['allow_extensions']option in the config file to ‘n’. That made the CP visible, but obviously I needed my extensions eventually. So I set the ‘allow_extensions’ setting back to ‘y’, then went into the database and disabled all the extensions there, planning to do process of elimination to see if there was a problem child.
What I discovered was that no matter which extension I enabled, the CP went blank again. It’s almost as if the act of enabling an extension is what’s causing the blank CP.
As I mentioned, the site is running EE v1.6.7. I can’t upgrade because my license has expired. Here’s a list of my installed extensions:
jQuery for the Control Panel v1.1.1
FieldFrame v1.4.5
LG Add Sitename v1.2.0
LG Image Preview v1.0.0
LG Tiny MCE v1.3.3
Structure Extension v1.1
