Determining whether an entry is a single day or last for two or more days.
June 29, 2011 6:23am
Subscribe [4]
  • #1 / Jun 29, 2011 6:23am
    D.Warren
    I am trying to set up a scheduled closings section in a template. My hurdle is some closings are a single date and some are a date range that is two or more days.
    <ul>
          {exp:channel:entries channel="closings" show_expired="yes" status="Scheduled"
          show_future_entries="yes" year="{current_time format="%Y"}" orderby="date"}
          <li>{title} {entry_date format="%F the %j<sup>%S</sup>"}</li>
    </ul>
    <ul>
          <li>{title} {entry_date format="%F the %j<sup>%S</sup>"} through {expiration_date format="%F the %j<sup>%S</sup>"}</li>
    </ul>
    I guess some sort of if statement could take care of this but not sure how to go about that, possibly some php. I am mainly a HTML/CSS guy so my php knowledge is lacking.
    EE2 v2.1.3
    http://new.zackhallmd.com/index.php/contact
    EDIT: This was my first post, looks like I should have posted it in “Community Help” not sure if it can be moved or I should delete and repost to “Community Help”?
    Moved to Community Help forum by Moderator
  • #2 / Jun 29, 2011 2:46pm
    Welcome to the ExpressionEngine forums, D.Warren. I’ll be happy to move it for you..
  • #3 / Jul 04, 2011 1:31pm
    D.Warren
    I was making this way more complicated than it was. All I needed to do was to compare the entry_date to the expiration_date.
    <ul>
            {exp:channel:entries channel="closings" show_expired="yes" status="Scheduled" show_future_entries="yes" year="{current_time format="%Y"}" orderby="date"}
        <li>
            {if {entry_date format="%m%d%Y"} != {expiration_date format="%m%d%Y"}}{title} {entry_date format="%F the %j<sup>%S</sup>"} through  {expiration_date format="%F the %j<sup>%S</sup>"}
            {if:else}{title} {entry_date format="%F the %j<sup>%S</sup>"}{/if}
        </li>
    </ul>
  • #4 / Aug 21, 2012 3:27pm
    OrganizedFellow
    The above solution (post#2) should work for me,
    but it is not.
    I am using v2.5.0 - Build Date: 20120507.
    {if {entry_date format="%m%d%Y"} != {expiration_date format="%m%d%Y"} }
    {if:else}
    Instead, I get a PHP parse error.
    Parse error: syntax error, unexpected ')' in /home/xxx/public_html/system/expressionengine/libraries/Functions.php(680) : eval()'d code on line 135
    Anyone have a solution?
  • #5 / Aug 22, 2012 7:59am
    e-man
    Try using either:
    {if '{entry_date format="%m%d%Y"}' != '{expiration_date format="%m%d%Y"}' }
    OR
    {if entry_date != expiration_date}
  • #6 / Aug 22, 2012 3:37pm
    OrganizedFellow
    Thanks e-man.
    Giving that a try.
